Siebel Installation Guide for UNIX > Additional Postinstallation and Configuration Tasks > Configuring the Siebel Gateway Name Server for Automatic Start >
Configuring the Siebel Gateway Name Server for Automatic Start on HP-UX
Use the procedure in this topic to configure the Siebel Gateway Name Server to start automatically on HP-UX.
This topic is part of Configuring the Siebel Gateway Name Server for Automatic Start.
To configure the Siebel Gateway Name Server to start automatically on HP-UX
  1. Log on as root to the computer on which the Siebel Gateway Name Server was installed.
  2. Copy the file siebel_server to the /sbin/init.d directory, as follows:
    cp $SIEBEL_ROOT/bin/siebel_server /sbin/init.d
    In this command, $SIEBEL_ROOT is the full path to the Siebel root directory.
  3. Using any text editor, edit /sbin/init.d/siebel_server. Replace $SIEBEL_GATEWAY_ROOT with the path to the Siebel Gateway Name Server installation directory.
  4. Set the appropriate permissions by executing the following command:
    chmod 755 /sbin/init.d/siebel_server
  5. Create a soft link to /sbin/rc3.d/S720siebel_server from /sbin/init.d/siebel_server by executing the following command:
    ln -s /sbin/init.d/siebel_server /sbin/rc3.d/S720siebel_server
  6. Create a soft link to /sbin/rc2.d/K320siebel_server from /sbin/init.d/siebel_server by executing the following command:
    ln -s /sbin/init.d/siebel_server /sbin/rc2.d/K320siebel_server
  7. Create or edit /sbin/init.d/siebel_server_nonroot to add the following line:
    /usr/bin/su - SIEBEL_ACCOUNT -c "/sbin/init.d/siebel_server $1"
    In this command, SIEBEL_ACCOUNT is the nonroot user account installing Siebel Business Applications.
  8. Remove /sbin/rc3.d/S720siebel_server and /sbin/rc2.d/K320siebel_server, if they already exist.
  9. Execute the following commands:
    chmod 755 /sbin/init.d/siebel_server_nonroot
    ln -s /sbin/init.d/siebel_server_nonroot /sbin/rc3.d/S720siebel_server
    ln -s /sbin/init.d/siebel_server_nonroot /sbin/rc2.d/K320siebel_server
Siebel Installation Guide for UNIX Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
