Siebel Installation Guide for UNIX > Installing the Siebel Database on the RDBMS > About Installing the Siebel Database > About Installing a DatabaseWhen you choose Install Database from the Siebel Database Operation screen in the Database Configuration Wizard, the utility performs several tasks within the database instance that you have already created. The Database Configuration Wizard is available on the computer on which you installed the Siebel Server and the Database Configuration Utilities. Before installing the Siebel database, review all of the applicable requirements. The Install Database operation does the following:
This topic is part of About Installing the Siebel Database. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
