Siebel Installation Guide for UNIX > Configuring Siebel Enterprise Server Components and the Siebel Web Server Extension > Installing the Siebel DatabaseIf you do not have an existing Siebel database, then you have to use the Siebel Database Configuration Wizard to install this database. This task is described in Installing the Siebel Database on the RDBMS. Before you install the Siebel database, you must review the guidelines described for your RDBMS in Configuring the RDBMS. This task is a step in Roadmap for Installing and Configuring Siebel Business Applications for a New Deployment. When you are following the task sequence in this roadmap, you must perform the Siebel database tasks before you can configure the Siebel Server, as described in the following topic. Related Topics |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
