Siebel Installation Guide for UNIX > Installing Siebel Charts > Enabling jQuery ChartsOptionally, for Siebel Business Applications that are deployed using Siebel Open UI, you can use jQuery Charts as a substitute for the NetCharts Server product described in this chapter. This feature is available in Siebel Innovation Pack 2015 and later. In the current release, only 2D and 3D bar charts are supported using JQuery Charts. Customers can optionally configure Siebel Business Applications to use their own JavaScript charting libraries, to operate within the jQuery Charts framework. For more information about how to do this, see Configuring Siebel Open UI. NOTE: You can enable jQuery Charts at the enterprise level only, by setting a system preference as described in this topic. Siebel Business Applications that are deployed using high interactivity cannot use jQuery Charts. If you still have high interactivity applications that require charting functionality, then you must continue to use NetCharts Server instead of jQuery Charts. Use the following procedure to enable jQuery Charts.
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
