Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Installing and Using the Siebel Sample Database > Using the Siebel Sample Database with Siebel ToolsA Siebel Sample Database that you install with the Siebel Mobile Web Client can also be used with Siebel Tools. To configure this, copy the value of the ConnectString parameter from the [Sample] section of the application configuration file, and paste this value for the equivalent parameter in the tools.cfg file (located in Alternatively, you can install this sample database into the Siebel Tools directory instead of the Siebel Mobile Web Client directory. For information about installing Siebel Tools, see Installing Siebel Tools. NOTE: This information does not apply to the Siebel Sample Database that uses Oracle Database XE, as described in Installing the Siebel Sample Database That Uses Oracle Database XE. This topic is part of Installing and Using the Siebel Sample Database. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
