Siebel Installation Guide for UNIX > Installing Siebel Web Clients and Siebel Tools > Siebel Web Client Shortcuts and Startup Options > Creating Custom Siebel Application ShortcutsIf you want to customize Siebel Business Applications shortcuts described in Siebel Web Client Shortcuts, then you can do so by modifying shortcut properties and changing the value for the Target field. Generally, rather than modifying existing shortcuts or creating them from scratch, it is recommended that you copy existing ones and rename and modify the copies. Observe the following requirements for creating or modifying shortcuts:
This topic is part of Siebel Web Client Shortcuts and Startup Options. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
