Siebel Installation Guide for UNIX > Configuring the RDBMS > Configuring Siebel Server Connectivity to the Siebel DatabaseReview this topic to configure connectivity to the Siebel database from the computer where you will install Siebel Server. The database will already have been created, as described in this chapter. For database connectivity software requirements, see the Certifications tab on My Oracle Support. Oracle DatabaseVerify that the Oracle Database connectivity software is installed on each computer, according to the Oracle Database documentation. Siebel Server connections to the Oracle Database are made through dedicated server processes rather than through Oracle MTS; the use of MTS might negatively affect performance. Use Oracle's Easy Configuration utility to define a database alias with the proper connection information for your Siebel database. Record the connect string in Siebel Deployment Planning Worksheet. You specify this connect string when configuring the Siebel Enterprise. NOTE: Siebel Business Applications support the Oracle 32-bit client. Therefore, if you have installed the Oracle 64-bit client on your Siebel Server, then you must include IBM DB2Define a database alias with the proper connection information for your Siebel database. Record the connect string in Siebel Deployment Planning Worksheet. You specify this connect string when configuring the Siebel Enterprise. You can use the DB2 command line processor to define your database alias. For more information, see IBM DB2 documentation. IBM DB2 for z/OSFor information about configuring database connectivity for IBM DB2 for z/OS, see Implementing Siebel Business Applications on DB2 for z/OS. |
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
