Siebel Installation Guide for UNIX > Uninstalling Siebel Business Applications > Uninstalling Siebel Web Clients or Siebel Tools > Rolling Back Siebel ToolsUse the following procedure to roll back the installed current release, Siebel CRM version 15.0, for Siebel Tools and revert to Siebel CRM version 8.1.1 or a prior version 8.1.1.x release, or revert to Siebel CRM version 8.2.2 or a prior version 8.2.2.x release. In the procedure below, the example installation paths are those that might apply for previous releases that you subsequently migrated to the current release. NOTE: If you installed Oracle Database XE for use with Siebel Tools, and you plan to roll back Siebel Tools, then it is recommended that you first uninstall Oracle Database XE. For more information, see Uninstalling Oracle Database XE. NOTE: This topic describes only rolling back a migration installation, not rolling back a patchset installation. For patchset uninstallation (rollback), see Siebel Patchset Installation Guide for Siebel CRM, 1614310.1 (Article ID) on My Oracle Support. This topic is part of Uninstalling Siebel Web Clients or Siebel Tools.
| Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
