Siebel Installation Guide for UNIX > Verifying and Troubleshooting Your Installation > Configuring the Siebel Mobile Web Client When Neither Siebel VB nor Siebel eScript Is LicensedBy default, the Siebel Mobile Web Client has Siebel VB or Siebel eScript enabled. The parameter EnableScripting is set to True in the application configuration files. If this parameter is True, but neither Siebel VB nor Siebel eScript is licensed, then the Siebel Mobile Web Client does not start. An error message is returned, indicating that you must turn off Siebel VB or Siebel eScript before running the Siebel Mobile Web Client. To configure the Siebel Mobile Web Client when neither Siebel VB nor Siebel eScript is licensed |
Siebel Installation Guide for UNIX | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
