Siebel Installation Guide for Microsoft Windows > Additional Postinstallation and Configuration Tasks > Preparing to Run Siebel Server Components > Performing Additional Tasks to Configure Siebel ServersAfter installing and configuring a Siebel Server as described in this guide, you might have to perform some additional configuration tasks, such as setting parameters for the Siebel Enterprise, Siebel Server, or server components, such as Application Object Managers. An example configuration task is setting the server component parameters needed to enable or disable Siebel Open UI, as described in Enabling Siebel Open UI. You perform these types of configuration tasks with Server Manager, whether by using views in the Administration - Server Configuration screen or by using commands at the srvrmgr command line. For more information about using Server Manager, see Siebel System Administration Guide. This topic is part of Preparing to Run Siebel Server Components. Related Books |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
