Siebel Installation Guide for Microsoft Windows > Cloning a Siebel Installation > Process of Cloning a Siebel Installation >
Creating a Clone on a Source Computer
Use the following procedure to create a clone on a source computer. After you create a clone, you deploy the clone on a target computer. This task is part of Process of Cloning a Siebel Installation. To create a clone on a source computer
- Determine your goals for the cloning operation that you are performing.
- Log on to the server computer on which you will create the clone.
- Open a DOS command window.
- Copy the Siebel cloning utility and all of the relevant files to the target computer.
- Copy one of the existing properties files, and edit the copy appropriately for your operation to create a clone. Use a properties file that is similar to one of the following:
- Enter a command like the following to run the Siebel cloning utility:
clone.bat -p properties_file
In this command, properties_file is the name of the properties file that you prepared for this operation.
- When the operation is complete, validate the creation of the snapshot file in the specified location. Also review the command output and the log file to confirm that the operation completed successfully without any errors.
- If errors are encountered when creating the clone, then do the following:
- Delete the snapshot file.
- Review requirements and correct errors.
- Restart the operation to create the clone.
