Siebel Installation Guide for Microsoft Windows > Installing Siebel Web Clients and Siebel Tools >
Enabling and Disabling Siebel QuickStart
Instructions are provided in the following procedures for enabling and disabling Siebel QuickStart agent and the Windows service Siebel QuickStart Service. For more information about Siebel QuickStart, see About Siebel QuickStart. Enabling Siebel QuickStart
You enable Siebel QuickStart in the Siebel Mobile Web Client. To enable Siebel QuickStart
- Start a Siebel application with the Siebel Mobile Web Client and the local database. For example, double-click the shortcut for Siebel Call Center for your applicable language.
- In the Siebel login screen, check the Enable Siebel QuickStart check box, and log in.
The Siebel QuickStart agent is loaded into memory for the rest of the Windows session, and it is loaded again when the user logs in to Windows subsequently, unless the user disables it. If you disable the service named Siebel QuickStart Service, then the agent stays loaded in memory for the rest of the Windows session only.
Disabling Siebel QuickStart from the Login Screen
You can disable Siebel QuickStart from the login screen. To disable Siebel QuickStart from the login screen
- Start a Siebel application with the Siebel Mobile Web Client. For example, double-click the shortcut for Siebel Call Center for your applicable language.
- In the Siebel login screen, clear the Enable Siebel QuickStart check box (if it is checked), and log in.
The Siebel QuickStart agent is not loaded for this Siebel application session, and does not load subsequently, unless it is explicitly specified. You might also choose to disable the service Siebel QuickStart Service.
Disabling Siebel QuickStart from the System Tray
You can disable Siebel QuickStart from the system tray. To disable Siebel QuickStart from the system tray
- Right-click the Siebel icon in the system tray, and select Disable On Startup.
This option is available only if the Siebel application is not running, or was not started using Siebel QuickStart.
The Siebel QuickStart agent exits. The agent does not load subsequently, unless it is explicitly specified. You might also choose to disable the service Siebel QuickStart Service.
Disabling Siebel QuickStart from the Siebel QuickStart Service
You can disable Siebel QuickStart from the Siebel QuickStart Service. To disable Siebel QuickStart from the Siebel QuickStart Service
- Navigate to Control Panel, Administrative Tools, and then Services.
- Select Siebel QuickStart Service, click Action, and then Properties.
- Change the startup type for this service from Automatic to Disabled.
The service Siebel QuickStart Service will no longer run automatically when you log in. If you want to reenable it, then change the startup type back to Automatic.
