Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring an Oracle Database for Siebel Business Applications > Guidelines for Creating Oracle Database ObjectsSiebel Business Applications provide sample scripts (CrBlankOracleSiebelDEMO.sql and CrBlankOracleSiebelDEMOPostCrDB.sql), located in the Use the settings in the script as guidelines for your initial configuration. Your final settings will vary depending on the server hardware configuration, the number of users, and the type of workload. Use a small, nonproduction environment for testing purposes. Before using these scripts, read the file CrBlankOracleSiebelDEMOReadMe.txt. See also Overview of Database Configuration. After you install the Database Configuration Utilities on the Siebel Server computer, as described in Installing Siebel Enterprise Server Components and the Siebel Web Server Extension you can modify the database table and index creation scripts to specify the tablespace names that you created for Siebel tables and indexes. For more information, see Guidelines for Overriding Oracle Database Default Tablespaces for Database Objects. Additional information about Oracle Database configuration and tuning options is available from Oracle, your hardware vendor, and other sources. This topic is part of Configuring an Oracle Database for Siebel Business Applications. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
