Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring an Oracle Database for Siebel Business Applications > Guidelines for Installing the Siebel Database in a Pluggable DatabaseYou can install the Siebel Database in a multitenant environment with versions of Oracle Database that support this feature. To do so, first create a pluggable database within the container database. Then create a corresponding entry for the pluggable database in tnsnames.ora. This entry must specify the service you will use to connect to the pluggable database. When you run grantusr.sql, you do so in the pluggable database rather than in the container database. Database settings you specify in the Siebel Configuration Wizards must be those for the pluggable database and you must create the Siebel schema within the pluggable database. For more information about creating a pluggable database and about managing a multitenant environment, see Oracle Database documentation on Oracle Help Center, particularly the guides listed. This topic is part of Configuring an Oracle Database for Siebel Business Applications. Related Books |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
