Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring a Microsoft SQL Server Database for Siebel Business Applications > Guidelines for Overriding Microsoft SQL Server Default Tablespaces for Database ObjectsSiebel Business Applications provide the option of overriding the default storage parameters for the tablespaces that you create to hold specific tables or indexes. To do this, edit the ddl.ctl file located in the NOTE: The ddl.ctl file must not be modified except by a qualified DBA. For each Siebel table, you can specify a tablespace by using the Table Space parameter. In the following example, the tablespace for the table S_APP_VIEW is set to This topic is part of Configuring a Microsoft SQL Server Database for Siebel Business Applications. As shown in the example that follows, you can use the Table Space parameter to set storage parameters for specific tables: [Object 219] For an example (IBM DB2) of overriding the defaults for specific tables and indexes, see Guidelines for Overriding IBM DB2 Default Tablespaces for Database Objects. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
