Siebel Installation Guide for Microsoft Windows > Configuring the RDBMS > Configuring an Oracle Database for Siebel Business Applications > Guidelines for Selecting a Language for Oracle DatabaseWhen creating your database, you must specify the character set at the database level. You specify other language characteristics at the database client level. This topic is part of Configuring an Oracle Database for Siebel Business Applications. Related TopicsTo specify the character set of your database
National Character SetSiebel Business Applications do not use the three data types that store Unicode data using the national character set (NCHAR, NVARCHAR2, NCLOB). The default national character set, AL16UTF16, is acceptable. Sort Order and Date FormatFollow the documented Oracle Database guidelines for client-level settings for the NLS_SORT and NLS_DATE_FORMAT parameters. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
