Siebel Installation Guide for Microsoft Windows > Requirements for Installing and Configuring Siebel Business Applications > Requirements for Installing and Configuring the Siebel Web Server Extension > Siebel Web Server Extension Requirements for Siebel Load BalancingIf you will use Siebel native load balancing for your Siebel Servers, then you must generate the load-balancing configuration file (lbconfig.txt). This topic is part of Requirements for Installing and Configuring the Siebel Web Server Extension. After you create the SWSE logical profile, you generate the load balancing file and place the file in the SWSE logical profile directory. When you apply the profile to an installed SWSE instance, the SWSE Configuration Wizard copies the lbconfig.txt file to the installed SWSE. After initially applying the SWSE logical profile, you might have to generate the lbconfig.txt file again after installing and configuring additional Siebel Servers that will participate in load balancing. Then apply the SWSE logical profile again. For more information, see Process of Configuring the Siebel Web Server Extension and Process of Configuring Load Balancing for Siebel Business Applications. |
| Siebel Installation Guide for Microsoft Windows | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
