Siebel Installation Guide for Microsoft Windows > Uninstalling Siebel Business Applications >
About Uninstalling Earlier Versions of Siebel Business Applications
To uninstall an earlier version of Siebel Business Applications software, you must use the documented uninstallation method for that version, as follows. For each version, always use the latest revision of the documentation that applies for the Siebel CRM version that you are uninstalling. For Siebel CRM version 8.1.1.14 or 8.1.1.11
- For the full uninstallation or rollback uninstallation instructions for Siebel CRM version 8.1.1.14 (Siebel Innovation Pack 2014) or version 8.1.1.11 (Siebel Innovation Pack 2013), see the version of the Siebel Installation Guide for the operating system you are using, the guide that you used when you installed Siebel CRM version 8.1.1.14 or 8.1.1.11. The most recent applicable guides, including those for these releases, are available on My Oracle Support, at 1461732.1 (Article ID).
For Siebel CRM version 8.1.1 and version 8.1.1.x (through version 8.1.1.10)
- For the full uninstallation instructions for Siebel CRM version 8.1.1, which used the InstallShield versions of the Siebel Enterprise Server and Siebel Web Server Extension (SWSE) installers, see the version of the Siebel Installation Guide for the operating system you are using, the guide that you used when you initially installed. The most recent applicable guides that cover the InstallShield installers, version 8.1, Rev. A, are available on My Oracle Support, at 1461732.1 (Article ID).
- For the full uninstallation instructions for Siebel CRM version 8.1.1.8 through version 8.1.1.10 (when Siebel Enterprise Server and SWSE were installed as a new installation), see the version of the Siebel Installation Guide for the operating system you are using, the guide that you used when you initially installed. The most recent applicable guides, version 8.1, Rev. D, are available on My Oracle Support, at 1461732.1 (Article ID).
- For the Siebel Fix Pack uninstallation instructions for Siebel CRM version 8.1.1.x Fix Pack releases through Siebel CRM version 8.1.1.10 (when Siebel Enterprise Server and SWSE were installed as a patch installation), see the applicable Siebel Maintenance Release Guide on My Oracle Support, 880452.1 (Article ID). Different uninstallation options apply for different Siebel Fix Pack releases. In particular, uninstallation options are different for Siebel CRM versions 8.1.1.8 and later, compared to Siebel CRM versions 8.1.1.1 through 8.1.1.7.
For Siebel CRM version 8.2.2.14 and version 8.2.2.4
- For the full uninstallation or rollback uninstallation instructions for Siebel CRM version 8.2.2.14 (Siebel Innovation Pack 2014) or version 8.2.2.4 (Siebel Innovation Pack 2013), see the version of the Siebel Installation Guide for the operating system you are using, the guide that you used when you installed Siebel CRM version 8.2.2.14 or 8.2.2.4. The most recent applicable guides, including those for these releases, are available on My Oracle Support, at 1461732.1 (Article ID).
For Siebel CRM version 8.2.2 and version 8.2.2.x (through version 8.2.2.3)
- For the full uninstallation instructions for Siebel CRM version 8.2.2, see the version of the Siebel Installation Guide for the operating system you are using, the guide that you used when you initially installed. The most recent applicable guides, version 8.2, Rev. C, are available on My Oracle Support, at 1461732.1 (Article ID).
- For the Siebel Fix Pack uninstallation instructions for Siebel CRM version 8.2.2.x Fix Pack releases through version 8.2.2.3, see the applicable Siebel Maintenance Release Guide on My Oracle Support, 1441523.1 (Article ID).
For Siebel CRM versions 8.0, 7.8.x, or 7.7.x
- For the uninstallation instructions for Siebel CRM version 8.0, 7.8.x, or 7.7.x, see version 8.0, 7.8, or 7.7 of the Siebel Installation Guide for the operating system you are using.
For Siebel CRM versions 7.5.x, 7.0.x, or 6.x.x
- For the uninstallation instructions for Siebel CRM versions 7.5.x, 7.0.x, or 6.x.x, see the applicable version of the Siebel Server Installation Guide for your operating system. See also Siebel Web Client Administration Guide, Siebel Tools Reference, or other applicable documents for these earlier versions.
Related Topics
Installing and Deploying Siebel Business Applications with Multiple Languages
About Uninstalling Siebel Business Applications
Related Books
Earlier versions of the Siebel Installation Guides on My Oracle Support, 1461732.1 (Article ID)
