Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide > Appointment Booking Integration > Overview of Appointment Booking IntegrationThe appointment booking process includes the following flows:
A composite is a deployment unit of the Service-Oriented Architecture (SOA) composite architecture that Oracle SOA Suite 11g supports. A composite includes various components, such as Mediator, BPEL flow, Adapters, and so forth. Siebel Field Service Integration to Oracle Real-Time Scheduler creates a single SOA composite to perform tasks that are related to the Appointment Booking System (ABS). The entry point to this composite is an outbound Web service call from Siebel CRM. The Web Service Definition Language (WSDL) file defines the operations and the expected message formats. The service that is available is the entry point that Siebel CRM uses to target the Siebel CRM Web service request. Separate operations are defined within the WSDL to book an appointment, cancel an appointment, and so forth. A single Business Process Execution Language (BPEL) process handles requests that occur in this composite. The mediator sets the OPERATION_TYPE global variable in the BPEL process in one of the following ways:
This integration handles these requests so that it can use a single Business Process Execution Language (BPEL) process for these tasks and so that it can place a switch inside the BPEL that calls the appropriate Oracle Real-Time Scheduler Web service. For more information, see Integration Services. |
| Siebel Field Service Integration to Oracle Real-Time Scheduler Implementation Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
