Testing Siebel Business Applications > Functional Test Object Reference > SiebTree ObjectThe SiebTree object provides methods and properties that allow you to manipulate a tree view object in a test automation environment. ParentThe SiebTree object is a child of the SiebApplet Object. TypeThe SiebTree object is a singleton multivalue object that is one of the Complex Control Objects. EventsThe SiebTree object has the following events. NOTE: The Position parameter of the Collapse, Expand, and Select events is a String that indicates the position of the node in the tree. It is in the format MethodsThe following methods are available from the SiebTree object: For a description of these methods, see SiebTree Methods. PropertiesThe SiebTree object has the following properties.
| Testing Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
