| Bookshelf Home | Contents | Index | PDF | ![]()     |
 Testing Siebel Business Applications > Functional Test Object Reference > SiebApplication Methods > SetTimeOut MethodThe SetTimeOut method specifies the length of time to wait for the application to return from an operation before timing out. Available fromSyntaxReturnsAn Integer indicating the previous timeout value (in seconds). UsageWhen the timeout is exceeded, the test tool stops execution of the script, and displays an error dialog box. The new timeout value is valid in the current test script until the next SetTimeOut is executed or the application restarts. When the SetTimeOut method is not used or it goes out of scope, the default value of 60 seconds is used.  |
| Testing Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
