 Testing Siebel Business Applications > Functional Test Object Reference >
SiebCommunicationsToolbar Object
The SiebCommunicationsToolbar object provides methods and properties that allow you to manipulate the communications toolbar in a test automation environment.  Parent
The SiebCommunicationsToolbar object is a child of the SiebApplication Object.  Type
The SiebCommunicationsToolbar object is one of the Custom Control Objects.  Events
The SiebCommunicationsToolbar object has the following events.
    Click (ButtonName)  |
    Clicks a button. ButtonName is a String that specifies the RepositoryName of the button.   |
    SelectWorkItem (ItemName)  |
    Selects a WorkItem. ItemName is a String that specifies the WorkItem to select.   |
    SetText (Text)  |
    Enters text in the text box. Text is a String that specifies the text to enter.   |
    ShowButtonToolTip (ButtonName)  |
    Displays the tooltip for the button. ButtonName is a String that specifies the RepositoryName of the button.  This event is significant because the CommunicationsToolbar tooltip is dynamic, causing a round-trip to the server.   |
 Methods
The following methods are available from the SiebCommunicationsToolbar object:
For a description of these methods, see SiebCommunicationsToolbar Methods. Properties
The SiebCommunicationsToolbar object has the following properties.
    ClassName = "SiebCommunicationsToolbar"  |
    Const String  |
    See Common Test Automation Object Properties for a description of this property.   |
    CurrentWorkItem  |
    String  |
    Indicates the currently selected work item.   |
    IsEnabled  |
    Boolean  |
    IsVisible  |
    Boolean  |
    Indicates whether or not the object is enabled.  You can not checkpoint this property because the control is not rendered by the browser when it is not visible. However, you can manually write script code to check the property.   |
    MediaType  |
    String  |
    Indicates the type of media.  |
    Message  |
    String  |
    The communication channel information displayed next to the Siebel menu that indicates where the message comes from (for example, Call Display).   |
    RepositoryName = "SiebCommunicationsToolbar"  |
    Const String  |
    Text  |
    String  |
    UIName = "CommunicationsToolbar"  |
    Const String  |
    WorkItemDuration  |
    String  |
    Indicates the duration of the currently selected work item.  |
