Testing Siebel Business Applications > Functional Test Object Reference >
SiebList Object
The SiebList object provides methods and properties that allow you to manipulate a list object in a test automation environment.
Parent
The SiebList object is a child of the SiebApplet Object.
Type
The SiebList object is a singleton container object that is one of the Complex Control Objects. Due to the complex nature of this object, it is also a collection object.
Events
The SiebList object has the following events.
Event Name
Description
ActivateRow (RowNumber)
Activates a row in the list. RowNumber is an Integer that indicates which row to activate, based on the number of currently visible rows. (The show more or show less button determines the number of currently visible rows. )
AscendSort (ColumnRepName)
Sorts the list on the column in ascending order. ColumnRepName is a String that indicates the RepositoryName of the column to sort on.
ClickHier
Toggles the active row between expanded and collapsed (for hierarchical lists).
DescendSort (ColumnRepName)
Sorts the list on the column in descending order. ColumnRepName is a String that indicates the RepositoryName of the column to sort on.
DoubleClick (RowNumber, ColumnRepName)
Double-clicks a row. RowNumber is an Integer that specifies the row to double-click. ColumnRepName is a String that specifies the RepositoryName of the column to double-click.
The ColumnRepName argument is optional. When recording a script, ColumnRepName is recorded only when the double-click occurs on a control in the row.
DrillDownColumn (ColumnRepName, RowNumber)
Clicks a drilldown link. ColumnRepName is a String that specifies the RepositoryName of the column that contains the drilldown link. RowNumber is an Integer that specifies the row that contains the drilldown link, based on the number of currently visible rows (determined by show more/less).
FirstRowSet
Navigates to the first set of records in the list.
LastRowSet
Navigates to the last set of records in the list.
NextRow
Navigates to the next row in the list.
NextRowSet
Navigates to the next set of records in the list.
PreviousRow
Navigates to the previous row in the list.
PrevRowSet
Navigates to the previous set of records in the list.
SelectRow (RowNumber, SelectType)
Activates a row in conjunction with a multiselect key. RowNumber is an Integer that specifies which row to activate, based on the number of currently visible rows (determined by show more and show less). SelectType is a String that specifies which multiselect key (either Shift or Control) to use. If SelectType is not defined, no multiselect key is used.
ToggleFreezeColumns (ColumnRepName)
Freezes or unfreezes the columns to horizontal scrolling. ColumnRepName is a String that specifies the RepositoryName of the last column to toggle.
This event is generated by a double-click on a column header within a list applet. The freeze begins with the first column and ends with the double-clicked column.
Methods
The following methods are available from the SiebList object:
For a description of these methods, see SiebList Methods.
Properties
The SiebList object has the following properties.
Property Name
Type
Description
ActiveRow
Integer
Specifies which row is currently active, based on the number of currently visible rows (determined by show more and show less).
ClassName = "SiebList"
Const String
See Common Test Automation Object Properties for a description of this property.
ColumnsCount
Integer
Specifies the number of currently visible columns in the list.
RepositoryName = "SiebList"
Const String
RowsCount
Integer
Specifies the number of currently visible rows (determined by show more and show less).
SelectedRows
String
A pipe-delimited string of row numbers that are currently selected.
UIName = "List"
Const String
Testing Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
