Testing Siebel Business Applications > Functional Test Object Reference > SiebTask ObjectThe SiebTask object provides methods and properties that allow you to manipulate a task in a test automation environment. ParentThe SiebTask object is a child of the SiebApplication Object. TypeThe SiebTask object is a container object that is one of the Navigation Objects. EventsThere are no events associated with the SiebTask object. MethodsThe following methods are available from the SiebTask object: For a description of these methods, see SiebTask Methods. PropertiesThe SiebTask object has the following properties.
| Testing Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
