Testing Siebel Business Applications > Functional Test Object Reference >
SiebTaskAssistant Object
The SiebTaskAssistant object provides events and properties that allow you to manipulate the task assistant in a test automation environment.
Parent
The SiebTaskAssistant object is a child of the SiebApplication Object.
Type
The SiebTaskAssistant object is one of the Custom Control Objects.
Events
The SiebTaskAssistant object has the following events.
Event Name
Description
Close
Closes the task list.
Done
Clicks the Return To link.
Next
Clicks the See additional steps link.
Start (TaskId)
Clicks the link of the specified task to start a task. TaskId is a String that indicates the id of the task to start.
Step (StepNum)
Clicks the specified step. StepNum is a String that indicates the number of the step.
StepView (StepNum)
Clicks the View link for the specified step. StepNum is a String that indicates the number of the step.
Methods
There are no methods available from the SiebTaskAssistant object.
Properties
The SiebTaskAssistant object has the following properties.
Property Name
Type
Description
ActiveStep
String
Indicates the number of the current step.
ActiveTask
String
Indicates the id of the current task.
ClassName = "SiebTaskAssistant"
Const String
See Common Test Automation Object Properties for a description of this property.
RepositoryName = "SiebTaskAssistant"
Const String
StepCount
String
Indicates the number of visible steps.
TaskCount
String
Indicates the number of tasks in the current list.
TaskId
String
Indicates the name of the current task.
UIName = "TaskAssistant"
Const String
Testing Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
