Testing Siebel Business Applications > Functional Test Object Reference > SiebTaskUIPane ObjectThe SiebTaskUIPane object provides methods and properties that allow you to manipulate the task pane in a test automation environment. ParentThe SiebTaskUIPane object is a child of the SiebApplication Object. TypeThe SiebTaskUIPane object is a container object that is one of the Navigation Objects. EventsThe SiebTaskUIPane object has the following events. MethodsThe following methods are available from the SiebTaskUIPane object:
For a description of these methods, see SiebTaskUIPane Methods. PropertiesThe SiebTaskUIPane object has the following properties.
| Testing Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
