Testing Siebel Business Applications > Plan Testing Strategy > Test Plans >
Test Plan Schedule
For each test plan, a schedule of test case execution should be specified. The schedule is built using four different inputs:
  • Overall project schedule. The execution of all test plans must be consistent with the overall project schedule.
  • Component development schedule. The completion of component configuration is a key input to the testing schedule.
  • Environment availability. The availability of the required test environment needs to be considered in constructing schedules.
  • Test case risk. The risk associated with components under test is another important consideration in the overall schedule. Components with higher risk should be tested as early as possible.
Testing Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
