Siebel Database Upgrade Guide > Upgrading the Siebel Database > Process of Deleting Unshipped Languages from the S_LST_OF_VAL Table on UNIX >
Backing Up the S_LST_OF_VAL Table on UNIX
This task is a step in Process of Deleting Unshipped Languages from the S_LST_OF_VAL Table on UNIX. You back up your original S_LST_OF_VAL table before you begin deleting obsolete or unshipped languages. You can later import languages from this data file. To back up the S_LST_OF_VAL table on UNIX
- In Siebel Tools, back up the original S_LST_OF_VAL table.
- On the Siebel Server computer, navigate to the
SIEBSRVR_ROOT \bin directory.
- From this directory, execute a command like the following to run the Siebel dataexp utility (replacing $ tokens with actual values that represent the environment):
dataexp /u $UserName /p $Password /c "$ODBCDataSource" /d $SiebelTableOwner /f $DataFileToExport.dat /l $LogFile.log
The utility connects to the database, and displays the following prompt:
Connecting to the database...
Connected.
Exporting Tables
Enter table name:
- Type S_LST_OF_VAL, and hit Enter.
When the action is completed, the utility will display the following message:
Exporting Tables
Enter table name: S_LST_OF_VAL
Reading tables matching "S_LST_OF_VAL" ...
Exporting table S_LST_OF_VAL ... exported 30102 rows
Enter table name:
- Check the log file for errors, to verify that the data file was created.
