Siebel Database Upgrade Guide > Upgrading the Siebel Database > Moving the Siebel Repository FilesEnvironments: Development and production test. Before doing the production test environment upgrade, you must copy the upgraded repository definition files (schema.ddl and custrep.dat) from the development environment to the production test environment. Requirement: If you modified repository objects or schema definitions after completing the development upgrade, then you must regenerate the schema.ddl and custrep.dat files. See Regenerating the Siebel Repository Definition Files.
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
