Siebel Database Upgrade Guide > Upgrading the Siebel Database > Regenerating SQL Files for a Siebel UpgradeEnvironments: Development and production test. If you enter incorrect information in the Database Configuration Utilities, then the SQL files the utilities generate will be incorrect and must not be used. You must run the utilities again, enter the correct information, and regenerate the SQL files. For example, you are upgrading a non-Unicode database. You run the Database Configuration Utilities and enter that you are upgrading a Unicode database. The SQL that the utility generates will be incorrect and cannot be used. You must regenerate the SQL files. When the Database Configuration Utilities generate SQL files, all previously generated SQL files are overwritten and newly created. To regenerate SQL files with the Database Configuration Utilities
Related Topics |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
