Siebel Database Upgrade Guide > Upgrading the Siebel Database > Preparing for a Nondevelopment Environment Siebel UpgradeEnvironments: Production test, production. Platforms: Windows, UNIX, IBM z/OS. If your installation does not include a development environment, then you do not need to merge your Siebel Repository. Instead, you can use the repository and schema definition files included in the Siebel Database Server installation. Before performing the upgrade, you must move and rename these files. To prepare for a Siebel upgrade in a nondevelopment environment
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
