Siebel Database Upgrade Guide > Siebel Database Upgrade Planning > About the Siebel Database Upgrade Log FilesEnvironments: Development, production test, production. Platforms: Windows and UNIX only. Does not apply to IBM z/OS. The Upgrade Wizard writes log files that provide detailed information on the upgrade processes, for example development-environment upgrep and upgphys. These log files provide detailed information on the upgrade steps, and they also list all errors. The Logparse utility analyzes and summarizes these log files. Upgrade Wizard Log FilesThe Upgrade Wizard writes the log files for a process to the following directory: Windows: UNIX: In these paths, For example, the log files for a Siebel development environment upgrep appear in the following locations: Windows: UNIX: You can select a different directory for the log files, by specifying a value for the Log Output Directory option in the Database Configuration Wizard. This option is for specifying a different subdirectory, under the Each subdirectory in the
The Logparse UtilityFor each upgrade process, the Logparse utility analyzes the log files in Parameters ReportThe Parameters report lists the total time required for the upgrade process. It also lists environment variables and input files used by the upgrade process. Use this report to verify that the upgrade was set up correctly. Step/Error SummaryThe Step/Error Summary lists each step in the upgrade process and whether it completed successfully. It also provides a link to a detailed step summary for each step. The detailed step summary lists database errors returned by the Upgrade Wizard, SQL scripts, and errors returned by the upgrade utilities called by the driver files, such as ddlimp, and dataimp. For Oracle Database and IBM DB2, the detailed step summary lists only unacceptable errors that must be corrected. The summary does not list benign errors. For Microsoft SQL Server, the detailed step summary lists all errors, including benign errors. An errors file ( Performance ReportThe performance report provides a list of the longest running SQL scripts and a list of SQL scripts returning no rows. The lists include a link to each script. Upgrade Tuner uses this information as input to help you tune upgrade performance. The report also provides two lists of DDL commands executed during the upgrade process. The DDL Summary lists the tables that were created, altered, or deleted by the ddlimp utility. The Native DDL Summary lists tables that were created, altered, or deleted by SQL scripts and includes a link to each script. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
