Siebel Database Upgrade Guide > Tuning the Siebel Upgrade Files > Starting and Stopping Siebel Upgrade TunerEnvironments: Production test environment only. Does not apply to production environment. Platforms: Windows and UNIX only. This topic describes how to start the Upgrade Tuner (upgtuner) from the Siebel Server installation directory on a Windows host. It also describe how to save or discard your changes when exiting Upgrade Tuner. Use the Upgrade Tuner to improve the performance of table creation, index creation, and SQL execution during the production upgrep step in the production test environment. Requirements
Starting Upgrade TunerUse this procedure to start Upgrade Tuner.
Saving Your Changes and Exiting Upgrade TunerUse this procedure to save your changes and exit Upgrade Tuner. To save your changes and exit Upgrade Tuner
Discarding Your Session Changes and Exiting Upgrade TunerUse this procedure to discard the changes you have made in the current session and exit Upgrade Tuner. No changes are made to upgrade files. Parallelize Table or Index Creation PagesChanges are discarded and do not display the next time you start Upgrade Tuner, if:
Deactivate 0-Row SQLsChanges are discarded and do not display the next time you start Upgrade Tuner, if:
To discard your changes and exit Upgrade Tuner
Related Topics |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
