Siebel Database Upgrade Guide > Siebel Postmerge Development Tasks > Updating Siebel Enterprise Application Integration (EAI)Environments: Development environment only. Platforms: Windows and UNIX only. If you use Enterprise Application Integration (EAI), then perform the following procedure to update the definitions of the Business Objects to account for changes in data type, length, edit format or other properties. To upgrade integration objects
| Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
