Siebel Database Upgrade Guide > Reviewing the Siebel User Interface > Reviewing Required Fields in the Siebel UIUpgrades from: All Supported Siebel releases. This topic applies only to upgrades using the Incorporate Custom Layout (ICL) feature. For more information, see Siebel Incorporate Custom Layout Upgrade Option. Environments: Development environment only. Platforms: Windows, UNIX, IBM z/OS. Reputility.log section: "Issue 9: List of Required Fields Missing from the UI." If you select Incorporate Custom Layout (ICL) during the repository merge, then the Web templates for the UI you are upgrading from are used to display the UI after the merge. The Web templates for the new release are not used. The Web templates used might not contain all the fields required by the new release. For example, a required field might be missing from the Web template used to display the Contacts applet. If you try to create a new record, the database will reject it because the record does not contain all the required fields. This section of the reputility log lists all the applets that have missing required fields. Use the Web Layout Editor in Siebel Tools to add the required fields. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
