Siebel Database Upgrade Guide > Postupgrade Tasks for the Siebel Database > Reapplying Schema Customizations in the Siebel DatabaseEnvironments: Development environment only. In the current release, tables are obsolete or have been replaced by new tables. If you added extension columns or foreign key (FK) columns to tables that are obsolete in the current release, then you must reapply these changes to the new tables. Reviewing Obsolete TablesThe upgrade process generates a report that you can review for information about tables that are either obsolete. This report,
Each obsolete table is listed with one of three codes:
If no tables are listed in If this file lists any tables, then reapply the custom extensions and foreign key columns to those tables in the current release using Siebel Tools. See Configuring Siebel Business Applications. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
