Siebel Database Upgrade Guide > Preparing Siebel Application Data for Upgrade >
Migrating Siebel Household Data
Upgrades: Applies to Siebel Financial Services upgrades from 7.x that have retained the Siebel 6.x form of household associations. Environments: Production test, production. Platforms: Windows, UNIX, IBM z/OS. Siebel CRM version 7.0.x introduced the Party model. This changed the way relationships between households and entities, such as activity and claim, are handled. You have two options for migrating household data:
- Migrating household relationships to the Party model (recommended)
- Retaining the Siebel 6.x form of household relationships
Migrating Household Relationships to the Party Model
To check household data integrity and support migration of household data to the Party model, you must run the household verification script (HH_MIG_populate.sq l). The script verifies that at least the same number of entities will belong to a household after the upgrade as belong to it before the upgrade. The household verification script makes the following assumptions:
- A household has at least one contact.
- The primary contact of a Policy/Financial Account is one of the contacts associated with this Policy/Financial Account.
- The primary contact of a Claim is one of the contacts associated with this Claim.
- The primary contact of an Opportunity is one of the contacts associated with this Opportunity.
- The primary contact of a Company is one of the contacts associated with this Company.
The script populates a temporary table with data, TEMP_HH_OBJ_MIG and generates a report based on an output file. Output is in the form of row IDs. The script verifies that every household associated with an entity includes a contact associated with that entity. If there is no output, then this means data integrity is good, and no action is required. If you receive output, then you must examine the relationship between contacts and households. To run the household verification script
- Type the following command:
odbcsql /U Tableowner /P Password /S ODBCDataSource /a /c REM /separator / /O OutputFileLocation \HH_Mig_populate.txt /L LogFileLocation \HH_Mig_populate.log ScriptLocation \HH_Mig_populate.sql /v y
odbcsql /U Tableowner /P Password /S ODBCDataSource /a /c REM /separator / /O OutputFileLocation /HH_Mig_populate.txt /L LogFileLocation /HH_Mig_populate.log ScriptLocation /HH_Mig_populate.sql /v
where:
Tableowner is the tableowner
Password is the tableowner password
ODBCDataSource is the data source of the database
OutputFileLocation is the location of the output file:
- Windows:
SIEBEL_ROOT \log\HH_Mig_populate.txt
- UNIX
: $ SIEBEL_ROOT /log/HH_Mig_populate.txt
LogFileLocation is the location of the log file:
- Windows:
SIEBEL_ROOT \log\HH_Mig_populate.log
- UNIX
: $ SIEBEL_ROOT /log/HH_Mig_populate.log
ScriptLocation is the location of the script:
- Windows
: DBSRVR_ROOT \ database_platform \HH_Mig_populate.sql
- UNIX
: DBSRVR_ROOT / database_platform /HH_Mig_populate.sql
Windows example:
odbcsql /U Tableowner /P Password /S ODBCDataSource /a /c REM /separator / /O C:\sea7xx\siebsrvr\Log\HH_Mig_populate.txt /L C:\sea7xx\siebsrvr\Log\HH_Mig_populate.log C:\sea7xx\dbsrvr\DB2\HH_Mig_populate.sql /v y
- If you receive output, then review the temporary table and check the following for each contact. Make corrections as needed:
- Contact is correct and household is incorrect.
- Contact is incorrect and household is correct.
- Contact is incorrect and household is incorrect.
