Siebel Database Upgrade Guide > Preparing a Microsoft SQL Server Database for a Siebel Upgrade > Verifying Microsoft SQL Server Sort Order for a Siebel UpgradeEnvironments: Development, production test, production. Databases: MS SQL Server only. Verify that the sort order of the master database and the database instance are the same. This prevents repository merge failure due to sort order mismatch. Binary sort order is required for the development environment upgrade and strongly recommended for the production environment upgrades. When you install Microsoft SQL Server, the collation method of the database instance is set by default to dictionary sort order. Every database you create thereafter inherits this setting. When you create a database, you can accept the inherited sort order or specify the sort order. It is recommended that you set the sort order to binary at the Microsoft SQL Server instance level so that this sort order is inherited by newly created databases. The sort order of the master database cannot be changed without rebuilding the instance. Consult your Microsoft documentation for instructions on setting database collation. To verify that your database was created using a binary collation sequence
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
