Siebel Database Upgrade Guide > Preparing an Oracle Database for a Siebel Upgrade > Verifying the Oracle Database ODBC Definition for a Siebel UpgradeEnvironments: Development, production test, production. When you install a Siebel Server, the installer creates the ODBC definition for the Oracle Database you specify. When you upgrade your production test environment and your production environment, you must manually create an ODBC definition for connecting to your development environment database. Verifying or Editing an ODBC Definition on WindowsUse the following procedure to verify or edit an ODBC definition on Windows. To verify or edit an ODBC definition on Windows
If these entries are not present, then right-click in the data display pane, and choose New, and then String Value to add them.
Verifying or Editing an ODBC Definition on UNIXUse the following procedure to verify or edit an ODBC definition on UNIX. |
Siebel Database Upgrade Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
