Siebel Database Upgrade Guide > Overview of Siebel Database Environments >
Naming Conventions Used in This Guide
This guide follows several naming conventions:
- All supported Siebel CRM releases refer to the upgrade path from which you might upgrade to a certain Siebel Business Applications release.
- For more information about your upgrade applicability and for system requirements and supported platform certifications, see the Certifications tab on My Oracle Support.
NOTE: For Siebel CRM version 8.1.1.9 and later and version 8.2.2.2 and later, the system requirements and supported platform certifications are available from the Certifications tab on My Oracle Support. For more information, see article 1492194.1 (Article ID) on My Oracle Support. For earlier Siebel CRM versions, see Siebel System Requirements and Supported Platforms on Oracle Technology Network.
- Current release means the latest version of Siebel Business Applications.
- The term Windows refers to all Microsoft Windows operating systems listed as supported for this release in the Certifications tab on My Oracle Support.
- The term UNIX refers to all forms of the UNIX operating system listed as supported for this release in the Certifications tab on My Oracle Support.
- The term IBM z/OS refers to the IBM mainframe operating systems that are collectively referred to as z/OS and listed as supported for this release in the Certifications tab on My Oracle Support.
