Siebel Database Upgrade Guide for DB2 for z/OS > Generating the Siebel Upgrade Files > Preparing the Additive Schema and JCL Files on the z/OS Host > Transferring the Additive Schema, PRET, and Data Migration Files to the z/OS HostUse the following procedure to transfer the schema DDL files and the PRET and data migration files generated by the Upgrade Wizard on the midtier up to Pause #1 to the z/OS host. NOTE: Before transferring the generated files to the z/OS host, edit them as required by relevant publications such as bulletins, alerts, and Siebel Release Notes on My Oracle Support. To transfer the files generated on the midtier
NOTE: If the FTP script fails because the password prompt is suppressed, then add the password after the user name in the ftp_pause1.txt, ftp_stg1.txt, ftp_pause1.txt, ftp_pause2.txt, and ftp_pause3.txt files and repeat the procedure above. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
