Siebel Database Upgrade Guide for DB2 for z/OS > How the Siebel Database Upgrade Works > About the Siebel Upgrade Wizard and Driver FilesEnvironments: All environments. The Upgrade Wizard generates the files required to perform the upgrade of the Siebel database on the z/OS host and also makes changes to the Siebel database directly. After the Siebel Upgrade Wizard starts, it executes this process:
If ddlimp or dataimp (or any of the database utilities) encounter errors, they stop. When the errors have been corrected, you can launch the Siebel Upgrade Wizard, and the upgrade resumes from where it stopped. The Siebel Upgrade Wizard pauses on four occasions during the upgrade file generation process. At each pause, you must transfer the files that the Upgrade Wizard has generated to the z/OS host and execute them before you resume the upgrade. Message text at each pause informs you of the tasks you must perform. The files generated by the Upgrade Wizard are output by default to the Driver FilesThe Siebel Upgrade Wizard performs the upgrade by executing the commands and SQL scripts contained in driver files. Driver files are in ASCII text format and are organized into steps. The Upgrade Wizard reads the steps in the driver files and performs the commands contained in each step. In a driver file, steps are separated by a blank line, and each step begins with a File Execute Entry number. The key part of each step is the command or script to be executed. When an SQL script is specified, you can review the script and see what changes it will make to the Siebel database before running the Siebel Upgrade Wizard. Driver files are provided for each of the major upgrade operations. Examples of development environment upgrade driver files are as follows: Here is an excerpt from a driver file that controls a development environment upgrep from Siebel CRM version 8.1.1 to version Siebel Innovation Pack 2015, Patchset 5 or later (driver_upgrep_dev_811_mf.ucf). The excerpt contains two steps: [File Execute Entry 10] [File Execute Entry 10] How to Locate Upgrade Driver Files and SQL ScriptsDriver files are stored in the following location: Windows: UNIX: where For example, if you are upgrading from Siebel CRM 8.1.1, the driver files for the development environment upgrep are as follows:
Related Topic |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
