Siebel Database Upgrade Guide for DB2 for z/OS > Performing the Siebel Incremental Repository Merge >
About the Siebel Incremental Repository Merge
If you are upgrading from Siebel CRM version 8.1.1.x (SIA repository) to Siebel Innovation Pack 2015, Patchset 5 or later, you perform an incremental merge of the Siebel database. Performing an incremental repository merge is required if you intend to use the new features included in the Siebel Innovation Pack 2015, Patchset 5 or later. The process of performing an incremental repository merge is described in detail in Siebel Database Upgrade Guide. This chapter describes tasks that are specific to the z/OS platform. Where necessary, you are directed to Siebel Database Upgrade Guide for information on tasks that are common to all database platforms.
