Siebel Database Upgrade Guide for DB2 for z/OS > Creating the Siebel Staging Database > Preparing the z/OS Upgrade Environment and Creating the Staging Database >
Creating the z/OS Setup Data Sets
Perform the steps in the following procedure to create the z/OS setup data sets. To define and allocate z/OS setup data sets
- After you have successfully transferred the staging files generated by the Upgrade Wizard up to Pause #0, log on to the host/LPAR where the staging database is to be created.
- To create the REXX, CNTL and JCLLIB data sets, navigate to the
DSNHLQ .SIEBEL.JOB0 data set.
- Go to Edit mode on the data set and submit the job using the JCL in the
- After submitting the job, enter
cancel on the command line or press PF3 to save changes.
- Verify that the job ran successfully (return code is 0) and that the following data sets were created:
DSNHLQ .SIEBEL.EXEC
DSNHLQ .SIEBEL.JCLLIB
DSNHLQ .SIEBEL.SP.SPCNTL
- Verify that the following PDS members contain information that you defined in the Database Configuration Wizard on the midtier:
DSNHLQ .SIEBEL.EXEC(@TBOSTG) contains the value for the staging schema qualifier.
DSNHLQ .SIEBEL.EXEC(@TBOTAR) contains the value for the target schema qualifier.
