Using Siebel Tools > Checking Out and Checking In Projects and Objects > Using Checkout and Checkin > Viewing Differences Between Local Repositories and Server RepositoriesBefore you check in an object, you can compare the version of this object that the local repository contains to the version that the server repository contains. Siebel Tools compares the current state of this object to the state of the object when you checked it out. To view differences between local repositories and server repositories
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
