Using Siebel Tools > Customizing Objects > Creating, Modifying, Copying, Validating, and Deleting Objects > Creating ObjectsYou can use a wizard to create an object, or you can create it manually. It is recommended that you use a wizard. For example, to create a new business component, you use the Business Component Wizard. A wizard guides you while you configure a new object. It prompts you for the required property values and automatically configures any required child objects. If a wizard is not available for the object type that you want to create, then you can create it manually in the Object List Editor. For more information about using wizards and creating objects, see Configuring Siebel Business Applications. Using a Wizard to Create ObjectsThis topic describes how to use a wizard to create an object. To use a wizard to create objects
Using the Object List Editor to Create New ObjectsThis topic describes how to use the Object List Editor to create a new object. For more information, see Locating and Modifying Object Definitions in the Object List Editor. To use the Object List Editor to create new objects
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
