Using Siebel Tools > Localizing Strings and Locale Data > Converting Symbolic Strings >
Using a Batch File to Convert Strings
You can run the conversion utility from a batch file.
CAUTION:  If the Siebel Tools installation path includes a space, then you must enclose this path in quotes.
To use a batch file to convert strings
  1. Navigate to the SIEBEL_TOOLS_ROOT\BIN folder.
  2. Enter the following command:
    strconv "object_type" action user_Id password
    For example:
    strconv "Applet" export user_Id password
    The following table describes the parameters you can use to run the strconv.bat (string conversion) batch file. You set other parameters in the batch file. For information about the batch file, see comments that the batch file contains.
    Parameter
    Description
    object_type
    Object type to convert. For example:
    • Applet
    • Control
    • List Column
    action
    You can use one of the following values:
    • Export. The utility exports all convertible locale records.
    • Import. The utility imports the file that the object_type parameter identifies.
    user_Id
    The user name that you use to log in to the Siebel application.
    password
    The user password that you use to log in to the Siebel application.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
