Using Siebel Tools > Localizing Strings and Locale Data > Configuring Locale Data >
Displaying Controls and List Columns According to Locale
You can control how Siebel CRM displays a control or list column according to the locale requirements. CAUTION: To hide or display a control or list column, it is recommended that you modify a property. If you delete a control or list column, then Siebel Tools deletes it from all languages even if you enable language override.
The following example displays locale objects in an applet. To display controls and list columns according to locale
- Set the language mode.
For more information, see Setting the Language Mode.
- In the Object Explorer, expand the Applet tree.
- Do one of the following:
- Click Control.
- Expand the List tree, and then click List Column.
- In the Object List Editor, locate the object you want to modify.
For more information, see Locating and Modifying Object Definitions in the Object List Editor.
- Use the values from the following table to modify a property.
Control |
Visible |
If TRUE, then Siebel CRM displays this control in the Siebel client in the parent language and in all other languages that it supports. |
Visible-Language Override |
If you enable language override, then you can set this property to one of the following values:
- FALSE. Hides the control in the Siebel client.
- TRUE. Displays the control in the Siebel client.
For more information, see Enabling Language Override. |
List Column |
Show in List |
If TRUE, then Siebel CRM displays this column in the Siebel client in the parent language and in all other languages that it supports. |
Show in List-Language Override |
- FALSE. Hides the column in the Siebel client.
- TRUE. Displays the column in the Siebel client.
