Using Siebel Tools > Managing Repositories > Exporting and Importing Repositories >
Importing Repositories in UNIX Environments
This topic describes how to import repositories in a UNIX environment. To import repositories in UNIX environments
- Do Step 1 and Step 3.
- Make sure
$SIEBEL_ROOT is the current folder.
- Run a script, depending on the following UNIX shell that you are using:
- Korn shell. Run siebenv.sh.
- C shell. Run siebenv.csh.
- Make sure that the following environment variables use the following values:
- SIEBEL_ROOT.
This path must end in siebsrvr (for example, /usr /siebel /siebsrvr) .
- LANGUAGE.
Determines the language that the Database Configuration Wizard uses. The value of this variable is a text string that identifies the language (for example, enu for English).
- Run the following command to start the Database Configuration Wizard:
$install_path/config/config -mode dbsrvr
- In the Database Configuration Wizard, do the following:
- Enter information when the wizard prompts you.
- Use the Next and Back button to navigate between dialog boxes.
- Choose Import Repository when the wizard prompts you to choose a database operation.
- Specify to import your 8.x repository.
- Identify the location of where the custom CustRep.dat file resides.
- After you enter all the requested information, the wizard displays a message that is similar to the following. Click Next to continue:
Configuration is complete: configuration parameters will be saved to $Masterfile file when the wizard completes. Please run the following command line after you exit from this configuration wizard. This command will deploy the process you configured to the database.
$SIEBEL_ROOT/siebsrvr/bin/srvrupgwiz /m $SIEBEL_ROOT/siebsrvr/bin/$Masterfile
- The wizard displays the values that you entered in the Parameter Review window. To modify a value, click Back to return to the appropriate window.
- The wizard prompts you to click one of the following values:
- Yes. The wizard saves the configuration in a master file in the
$SIEBEL_ROOT/bin folder. It does not start the Upgrade Wizard. For information about how to start the Upgrade Wizard, see Siebel Database Upgrade Guide.
- No. The wizard does not save the configuration that you entered.
