Using Siebel Tools > Managing Repositories > Exporting and Importing Repositories >
Importing or Exporting Repositories at a Later Time
If you use the Database Configuration Wizard to export or import a repository, then it saves the values that you specify to the master_exprep.ucf file in the SIEBSRVR_ROOT\ folder. After the wizard finishes collecting information from you, it prompts you to export or to not export. If you choose not to export or not to import, then you can run the following command to do the export or import at a later time:
siebupg.exe /m master_exprep.ucfs
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
